Is that the same as ignition power?
If so with the ECU plug facing you it's the bottom row second wire in from the right.
Check here to be sure: http://www.apexi-usa.com look at the wiring for the AVC-R I think it's page 13 diagram 3b for the Pulsar, but do check?
well im looking at the s14 diagram and the ig12v is the same the rpm signal is the same and the 1 i cant find goes into terminal one on the s14 so it must b the same i'll go and try if i ent come back on the forum just assume im dead
