pushermanR
Car has started going through petrol like its going out of fashion...just put in a tenner to give it a run around before i put it away and go on hols...lasted about 20 miles before needle was off down to nil...
Cant work it out only thing i can think of is i tried to alter the idle screw(hope its the one on the inlet manifold under the back of the intercooler about four inches below it pasenger side)!!!!
Plus the timing slipped out because some dip had knacked the dizy bolts so i had to retap the threads!!!So my timing was running advanced glad no damage there!!!set it up at just below 20 deg
and the power seems to be a bit off...no missing strong through the rev range...
Could Air leeks cause these kind of problems the front mount pipe is looking a bit old and worn!!!!
Plus Merry Chrimbo everybody
