After nearly 2 years in the build, my gtir rally project is nearing MOT.
Couple of probs that you knowledgable people could help with please;
(All parts bought s/h from gtiroc members)
APEX SAFC i: The airflow indicates 98% on tickover on my multichecker (below), where it indicates 2% with the bypass harness. (probably right for tickover) The web shows a black and brown earth wire that my system does not have. At present I have white (AFM in) (from AFM) , yellow (AFM out) (ECU-16), black earth (ECU-108), green rpm (ECU-2 or 27: tried both) , red ign 12V (ECU-38) and thats it. I have one spare wire. (blue - for RB26)
MULTICHECKER:
Reads rpm 30% low (revcounter matches datascan software reading), Ign timing is fixed at -60 degress (tickover or revved) and Air Fuel ratio is about 10:1 where the (previously believable) luminition dash gauge reads very weak. New titania lambda installed. The m,checker is wired with white monitoring airflow (ECU pin 16) , pink is ignition (ECU pin 1), Ground is black ECU pin 17, Speed is green ECU pin 32, CAS is brown pin 31, CAS 120 degree is blue ECU pin 22, Power is red ECU pin 47. Light blue and grey not used.
All the above is from the web, but the pulsar is not directly referenced. The diagrams for the early safc are no longer on the official site.
Both sets of problems look like wiring issues to me. Has anybody else been here? And had the same/similar symptoms. Has anybody got any good links? The usual google subjects don't seem to help. I have spent hours trawling.
My safc part no. is 9612-0110, and it may be an early type (gen_1?). It has the five rotary knobs on the front.
Any help appreciated,
Regards,
Jon
MULTICHECKER:
Regards,
Jon
