Both have same size maps. Ultimate interfaces with crank angle sensor so you have a totally accurate idea of the ignition timing, Both can read the greddy pressure sensors. Ultimate can handle very large injectors, where as once you hit the TTPmin of the stock ECU the blue cant, and you run rich with no way to fix it (but thats injectors in excess of approx 800cc.
Ultimate has more maps and more external controls (Nitrous etc) and also antilag/full throttle shift/launch control. Its logging facilities are also much more advanced. There is loads of other stuff but thats the immediate main things that come to mind. Oh the ultimate can also remove the AFM completely if you want, you have to take a different (longer) approach to setting this up however.
