Its a Piggy back ECU (Thats what some people call it,.....I think :? ) so it uses the map on your standard ECU and then you can adjust the fuelling and timing with the E-manage, so you keep all the other functions that come on the standard ECU
Hope that sounds about right but it has been a long night :x and I have to be back up by 9:30am :shock: to drop my car off to be serviced.
if its been mapped to go on the supra then u will need to set all the settings to the correct ones for the gtir and zero and maps
then u can have it mapped for gtir
yeah the leads just a usb connector and the software is avaliable no problems
PM me if u need the software
theres also some rotary switches inside the case which need setting to the gtir postitions
