dump valves
GTIR-RACER
hello ive got a bov on my car atm but ive just got a baily dv26 put it on my car it still makes the same sound as the other one. also the noise comes out of the air filter. any body got any ideas why this is ? could it be hoesd up wrong?
gtir_pimp
how is it piped up? should just be the pipe from the underside of the plenum and a vacuum pipe that goes to it. and what kind of noise does it make? a whoooooosh or a chirp or other?
Yeah - I'd guess you've got no vacuum on the back of the piston.
As I asked on the other site; pictures?
darkyGTI-R
I had a bailey dv 26 was absolutely shite only because i've done the 4 hose loop to the throttle bodies for more vacuum after seeing mightymods on youtube lol
darkyGTI-R
It works even better with a stronger dv John with that mod the dv26 just stayed open as too much vacuum holding it's diaphram open,because of that I was loosing so much boost,much better with my sard one though!
I did that mod too, my normal vaccume line was clogged up so i did the MOD mentioned above.
I haven't had any problems with my dv26 though :S
On the ports with caps over them; they're for balancing the throttle bodies when you set them up.
You could also use the inlets from the PCV if you've taken it out.
