Dump Valve noise
Stoned
Righto
Now I got my DV working i'm thinking it sounds a bit naff! (I know, I never stop complaining :lol: )
It's a SARD BOV which apparently should sound the bollox. Basically the dump sounds like a really low rush of air, instead of a more chirpy hiss like most of the Dump Valves I have heard up until now.
Does adjusting the spring tension also adjust the note?
You can hardly even hear it with the radio on :roll:
my mates got the sard r2d2 on his s13 and that kinda hisses aswell so its not just yours,
My granny scarer makes all sorts of noises, under minimal load/boost it wont open and you just hear air through the tubby, bit more boost and it will hiss and tisscchhh, at full boost it will wake the dead :lol:
You could try winding the the screw out a bit. It will put less tension on the spring meaning the valve will open at lower boost and offer generally less resistance to the piston. It may then become louder :wink:
mattygti-r
also seeing as its just started working it becomes louder as the more boost you put throu it and when it starts to be run in for a while
Stoned
:D
I see lots of pointless journeys ahead!
R
r5ben
did someone say on a post the other day that there was a better place to take the feed from for the bov ?? making it sound better ? :roll:
Stoned
No, it was my post and it was about taking the vacumn line from somewhere so that it actually made a sound full stop
