Drain Plugs!
Shaun
:DHi guy's,can anyone tell me if there are any drain plugs and bleed plugs for the coolant on the SR20DET block,and where about they are if any :?:
jasegould
Even if you can find the block drain 1. I doubt youd be able to get a tool on to and 2. youll prob never be able to undo it anyway.
Drain the coolant from the radiator bottom hose, if you want you can flush the system thru with cold water from a hose.
From memory there are no bleeds.....but not 100%
