drain plug? ? /
rossdj1983
anyone know the size of the gearbox, transfer box and rear diff drian plug? save getting underthere tonight
I'm not sure about the rear diff, but a 1/2" and 3/8th square ratchet drive with extension will undo both the others.
chrism
How much fluid should I buy to do the gearbox,transferbox and reardiff?
Is it okay with the millers CRX 75W90?
jpward
rossdj1983 said:
till it overflows
True yet wastefull answer :lol:
Do a search the exact amounts are listed many times but about 4.5L did mine and i used Silkolene Syn 75 noticed a slicker gear change right away then again the oil was probably going on possibly 8 year old :oops:
Drain plugs are as Fast Guy said 1/2 & 3/8 rear is 1/2" so socket extention (short) and ratchet should be the ticket or you could buy a 13mm drain plug like me and you would see with using a ratchet spanner how much easier the diff fill plug is (Hint hint)
Top tip as usual undo top before bottom! :p
PS i needed a breaker bar for my gearbox drain they can be tight!
