down shift problems!
F
Fubawu
Hey guys, I am having a problem with down shifts or gear selections i.e 1st when the car is static. i.e It is very hard to get the car into gear (1st)(R) Also find down shifts tricky at speed. I was thinking it is the slave. Is this a common problem??
Thanks
John
vss irvine
yes mate slave cylinders do perish the seals, as well as the hose and the clutch master cylinder!
so could be any one of these, firts thing to do is have a good look about for any leaks, then try and bleed the slave system
F
Fubawu
What symptoms would a clutch master cause??
Thanks for the help
John
F
Fubawu
Ok, so my guess at the Slave should be correct as I have none of those issues.
