Yeah, as far as I know there is only one trace map with the two values for fuel and ignition at each point.
At the moment I'm running 1.4 bar on standard internals and standard tubbie. I had a mild det problem at 3500 - 4000 rpm on heavy loads at part throttle, like labouring up hills in the wrong gear
but I managed to get rid of that by retarding the ignition a little at that point ( I think the original map had an error ).
Apart from that I'm making really good torque and not seen any significant det or pinking. I'm building another stroker engine so I'm using this standard one to practice with
I know a lot of people say you shouldn't run over 1 bar etc on a standard engine, but I've never had any problems and I know a few other people who have done the same and not had any problems either.... Just luck probably
BTW, I'm using the standard Det sensor ( and an EGT as well ), but a Scooby friend of mine makes his own knock link boards so I'll be using a better sensor soon.
Couldn't really say how close the original map was to detting, but I wound in loads of advance before I had the WI and it never detted. I'm assuming the original map was built for safety and not performance. What I'm doing now is backing off the advance at low rpm ( no WI ) and advancing it more after the WI comes on, seems to work well.
Can't wait to get a wideband O2 though
