Do not tow with the wrong part of the car!!!
mreguest
as a warning to others!
do not wrap a tow rope around the front cross member/beams etc otherwise this happens!!!
http://s681.photobucket.com/user/mreguest_bucket/library/bent
only use the official towing eye! or I believe there is a way to wrap a hook/cable around a wishbone?
anyway the result was the bonnet had a 2 inch gap between it and the headlights when the bonnet was closed. the cross member/beam thingys were about 8 inches too far forward on the drivers side. A decent chunk of metal was separated from the chassis/main frame of the car and the metal work that the horns and radiator are connected to were misshapen...
blessing in disguise though because the shell was rotten bad in the arches and sills and one suspension turret, only a short time before MOT fail i reckon :?
Adam
mreguest
what were you trying to tow?
i wasn't trying to tow anything, on sprint day a friend was towing me from the track back up to the pits because my engine died, a rocker arm broke off... but luckily whilst i was queuing up to go out on track and not whilst hooning it around!
was a bit of a shitter having a £350 engine fix turn into a full reshell :doh:
