Do i need oil cooler ?
cmng
Do I need Oil cooler ?
Just realised my car Oil temp is about 105 to 110 C on the standard gauge
that time 150kmh on highway cruising for about 15 min
this is first time i take the car for 150kmh
it common ?
Mr GTiR
The main reason why people fit oil coolers is for track days or constant hard driving.
In your case I would fit an oil cooler just for the temperature of the country you live in.
As your seeing over 100 degrees on your oil temp guage I would fit one as your oil is nearly at boiling temp for oil.
Dooie Pop Pop
mine didn' t go over 95degree' s yesterday after i dreamed i gave it a similar good hard whupping (some on/off action) thats with a bigger turbo, an uprated rad and 16 row oil cooler;-)
think it was about 18 degree' s ambient over here...
cmng
mean highly recommended
should i get oil cooler kit only
or Oil cooler with relocation kit ?
i afraid oil pressure drop only
Water Temp is ok
Dooie Pop Pop
you need a thermostatic sandwich plate...i think thats what its called:oops: on my mocul kit it fits between the oil filter and the engine.
filter location is a matter of personal choice.
jpward
Water Temp is ok
Oil pressure shouldnt drop get cooler kit only
relocation kit just more hose & plate to install and there little room to work at car as is
Fitting mine next week
cmng
Yes.. i will have the sandwich plate with termostat
since found one Greddy Oil cooler kit with relocation kit for SR series
Thank
