Geo3
Hi guys new to this site, just tellin you my little story an spec or my R will be he he
Well i bought my R about year an a half ago, replaced the gearbox bearings as i got car cheap with them buggered...
So after 6months of driving an loving every minute an people askin what the hell it was i managed to fill the M5 up with white smoke :x . I presumude the turbo, so i removed the turbo an found traces of oil around no.4 cylinder exhaust oulet. So it was going to be either a piston ring or a valve stem oil seaM , either way it had to be ripped apart to have a look see what was wrong. Mean while i sent the turbo off to be looked at, which we found out was un repairable .......
Sat down an had a long think! spec now follows:
HKS adjustable cam gears
new cam rockers
jun 264 cams
1 new valve as was bent
re seated valves 3 seats
tomei 1.8 head gasket
nissan gasket set
skimmed head (new face)
port an polished head
flowed on nissan specific head flow bench
wisco 87mm pistons
shot peened rods
arp head bolts
arp conrod bolts
excedy clutch assy rated to 480ft
lightened an balanced crank
lightened stock flywheel
new shells
new oil pump
e-manage ultimate
forge breather kit
fmic kit
gt3071r
few bits left to get are:
fuel pump
injectors
fuel pressure regulator
tubular manofold
braided feeds for tubby
want an hoping for big bhp an torque
just wanted to see what you guys thought?
g
new cam rockers
jun 264 cams
nissan gasket set
wisco 87mm pistons
shot peened rods
arp head bolts
arp conrod bolts
new shells
new oil pump
e-manage ultimate
forge breather kit
fmic kit
gt3071r
fuel pump
injectors
tubular manofold
g
