Thanks guys,
This sounds like its exactly what the problem is / symptons, (a bit flat). I suspect this may have been either set off when I had a big problem with a lead down under load causing a massive missfire or when i had a fuel starvation problem caused by a bad connection?? - maybe anyway.
I have now cleared the fault anbd will recheck when ive done a few miles. Also, ill check the conection and wiring as best i can:?
Is it possible to test the sensor. or is it best to just replace?
wheres the best place to get a new Det sensor / how much?
Cheers - and thanks for your help on this
Lee
