swawuk
Really need some help. Been having trouble getting my R running after its been sitting for 5 years. I thought i had it sorted when I had the 55 all clear. I took it for a test run and it wasn't running right at all. checked the fault code again, 34 turns up. I thought I would check the resistance on pin 27 on ECU. Nothing! I spent some time getting the Knock Sensor off. Little Ba$tard! only a little tug and the cable snapped off. Brilliant I thought, a loose cable and thats it. To try it I bolted the sensor on the front of the engine. I tested the two pins, as you look at it bolted on the engine, the right pin had no reading at all. the left pin had 0.64 ohm resistance. When looking at the plug which snapped off, it had been resoldered. The one cable was connected to the right pin??????? which had no reading. I changed it to the left pin and ran a cable to pin 27. Checked fault code and 55. Test drove it, ran better, not right at all, considering engine has been highly modified. Fault 34 again.
Should my next step be getting the timing done, incase the det sensor is doing its job???
Is 0.64 ohm an ok reading for the sensor???
A random question, does the actuator need a pressure or a vacuum on it???
Any help will be much appreciated, sorry for the long story.
Steve
Steve
