Defi Guages
F
flying postman
been told there the nuts how much you talking here :?:
mattygti-r
I will have to confirm with definite prices later in the week but the Defis are indeed "the nuts" and look v.trick and are the best on the market IMO
The Defis will be in the region of......(and dont hold me to these prices) but to give u an idea and an example
52mm Boost (reads upto 35psi) £115
52mm Oil Pressure £140
52mm Air Fuel guage £100
etc
plus p+p
basically they look like this..........
http://www.defi-shop.com/product/dg/dg_type.html
will keep u all posted..
id think most people would be after the boost guage...(most popular) but ?
defi are loads of money
when i buy one you have to get the control unit as well.
I works out for a boost And control unit it's round the £200 mark
But u only have to buy one control unit.
mattygti-r
i know u need a control unit ( just the one) but the guages are v.expensive.
just seeing if anyone would like them?
the unit u can buy is about £65 then add your guage.
but u pay for quality :wink:
Nad
Yeah I am stuck between those and SPA gauges, but will prob go with the SPA's just because they are digital readout and give two readings per a gauge so means less space taken up as I dont like A Pillar pods as it creates a blind spot! :wink:
Nad
mattygti-r
oh but the 52mm i have dont need pillar pods nad :lol: and they are cheap like a budgie
plus come on they are defi! neat and trick
sure u dont want one?
Nad
Have u seen the SPA Gauges, speak for themselves really. Do Defi do a 52mm EGT?
Nad
Nad
Reason I am getting SPA gauges are below:
Selectable backlight color (red or green)
Adjustable backlight brightness
High resolution modes for 0.1 PSI, Deg C etc
Programmable button function, recall menu etc
Splash proof sensor connections
Extended temperature operation (for extreme climates) -20 to +70 Deg C
Stainless steel pressure and vacuum sensors
Programmable warning lights, low battery, averaging etc
Programmable outputs for driving external LED's or relays
Thermocouple options and kits available
Can display either Bar or PSI, Deg C or F
Its just the fact that they can control external relays if need I think is a great idea :!:
Nad
D
daBOODA
Defi's a porn! I wish I could afford to make my entire cluster using Defi's
