Dead GTIR HELP URGENT!
F
FiXXXeR
what i did was i took off the hi/lo switch off the engine its like a female clip onto the hi/lo thingy and i think that has earthed or something therefore killing a fuse and it only took 2 mins from takin the clip off
the siren started going off then 10secs later immobiliser kicked in and cant start it??
Any ideas? ive taken battery out d/c it etc what does anyone think what fuses should i check???????
very urgent as the car is literally dead cant start it or anything
it has no electrics at all
GartracS2
Check under the bonnet in the main fuse box the fusible links. They have a glass panel on top and you really need to have a close look to see if the fuse wire has broken. ;)
