db level
oddbodd
It is very important that the noise limits are clearly understood to avoid disappointment. These are specified and form part of our planning permission so there is no room for discretionary relaxation.
Although they can seem stringent to some, we operate our Motorsport Sensation programme, which includes Formula Palmer Audi single seaters and the Palmer Jaguars, in full compliance with these limits. They are very reasonable and ensure Bedford Autodrome creates the minimum disturbance to our neighbours.
Please read the following carefully because if your car, at any time, exceeds our noise limits you will not be allowed to drive it on our circuit.
At Bedford Autodrome we have two noise tests. First your car will be subjected to a static test, in which the noise level is measured 50cm away from your exhaust pipe with the engine at 75% of maximum rpm. The reading must not exceed 101 dB(A).
Secondly, and more significantly, your car must comply with our drive-by noise limits. The noise emission from your car must not exceed 87 dB(A) measured 20 metres from your car, which shall be accelerating maximally at over 60 mph.
All standard volume production cars will pass this test with ease, so, for example, if you have a standard Audi, BMW, Porsche, Subaru or Mitsubishi you will have no problems at all. The drive-by level will probably be less than 80 dB(A).
Cars, which tend to fail the test include most bike-engined cars, eg Westfields, Radicals and Caterhams, plus cars fitted with particularly loud “high performance” exhausts, as sometimes fitted to, for example, Caterhams, Lotuses, TVRs and Subarus.
If you are at all concerned that your car may not pass, it is advisable to either come to Bedford Autodrome in advance for a free noise check, in which case send an e-mail to julie.edland@palmersport.com to arrange this, or try to get an independent test done locally to you. You could try www.association-of-noise-consultants.co.uk to find a local noise consultant, but they are likely to charge you for this. Please treat any test done by a third-party as a guide to whether your car is likely to pass or fail and be very cautious if it is approaching the limit as the readings that are taken at Bedford Autodrome will be the deciding factor over whether your car is too loud.
It must be stressed that the drive-by limit at Bedford is not something that can be “cheated”. The noise monitor records continually and we also have other noise meters around the track, so please do not think you will necessarily be able to continue running if you can pass the initial check.
Any breach of any of these terms and conditions may result in you being asked to leave the circuit without refund. E & OE.
my system is mongoose turbo back running 1 bar 326bhp would it pass????
I havent had any experience of drive by tests so cant commment there :(
My mongoose was 99db at 4500 rpm at castle combe, but if that test is done at 75% of the maximum rpm (which would be 5625rpm) you could have problems there :?
OZ-Racing
We have a sound meter knocking about somewhere at work.
I'll have a play one lunchtime and let you know the results :wink:
