what are your views on these. thinking of getting one for the short term but will upgrade to a chip later on once funds allow. what would i be better doing.
If you get the Dawes Device I believe you will still need a remap/RR sesh which also costs. I would hold out a little longer & get the chip/ecu, you will enjoy it more.
You should be OK at 0.9bar just by upping the boost, but above that you realy should make sure your fuelling is spot on or you'll end up blowing the engine if you start detting.
