Mike kindly re-set up my dawes device as the way they had sent it to me was to have it installed as a bleed valve, but Mike showed me that it should actually run in-line!
While it was off i turned it down a little bit as i had a new front pipe put on so was scared of it over boosting, i drove it around for a bit and all seemed fine! Running about 0.8 bar, but that's from the standard gauge so can't be 100% sure......
I've now got a boost gauge which i'm going to install tonight, but basically i keep adjusting the dawes device but the boost doesn't seem to adjust now? I've undone it at least 3 turns, and it's still on 0.8 bar........ any ideas why this may be??
Should i try doing it up??
Sorry for the essay.........
