daft question time.
kyepan
there is a gromit on the lhs of the engine bay facing forwards, behind the suspension turret, and under that silver covered thingy.. it goes through into the passenger foot well. i'm sure there is probably a better one closer than that.
AJ4
You can come in through the grommet that the bottom air-con pipe comes through. Its a massive hole that is mostly filled with rubber, the pipe has a lot of room to move. Make a small slit in the rubber and push the cables through.
Otherwise ( but quite a long route ) is to go out of the drivers side wing and in through the grommet in the side of the pillar ( near the door hinges ). Its handy for guages etc that are mounted on the drivers pillar.
LeeSmith
go in throught the gromit under the aircon as Ross said,
probably best 2 use a wire coat hanger m8 - thats what i needed (attach the cable to it).
when it goes through u may need another person to look inside the car as u wiggle it around, its a tight squeeze & usually the coat hanger goes to far downwards and u will need o guide it through slowly.
