yeah it is hard to justify 2k for a gearbox, but power and reliability costs money, theres no shortcuts unfortunately.
my mrs knows how much it cost for that box, so ive gotta work a bit harder to get the dosh for our holiday now or the brown stuff will hit the fan:lol:
i like davey's style from up your neck of the woods (only cost him £300 for his:-D 8) )
its only that my car will be raced that i bought it as i cant afford to keep breaking down on track with gearbox failiures, it works out more expensive in the longrun with race entry fees, tyres and getting there, all going up the swanny because of possible breakdowns on track.
and it does not look good for me or the car
hopefully i will have the car up n running again in a month, so i may pop up your way possibly cadwell again to test car and set it up, be good if you can make it!
as far as i know the quaiffe set are a slightly higher ratio than standard, so you lose out on top end a little, and i believe the gears are semi helical which obviously makes them a lot stronger, but also noisier!
ideally i would have liked a ppg dogbox but i just cant afford one of those, so will have to make do with the quaiffe and see how the land lies.
if your just doing trackdays paul then i would just stick to a standard box if i were you, and when it eventually breaks, just stick another one in.
you maybe lucky and it may last for ages!
at 450bhp i would run a paddle clutch, dont think an organic one will be man enough for the job
