antgtir
Has anyone ever changed one of these??
I seem to have an oil leak from the gearbox area, however it seems to be the engine oil not gearbox oil. There is a small drain hole where the box meets the bottom end, i have smelt this oil and its defo not the gearbox oil as i first thought. I checked the engine oil and its low, this engine has never burnt oil so with the recent leak i seem to have picked up it does seem to be this. I know there is a seal on the crank end and ive been told that any leaks are designed to be caught in this area and allowed to leak out of the drain hole.
So my question is has anyone done this job before? If so how much of a pain in the rear was it? How much did the seal cost? How long did it take?
Hope ive explained the problem clear enough.
Thanks in advance,
Ant.
Thanks in advance,
Ant.
