copper washers
ex-gtir
oil outlet on block 12mm
water outlet on block 14mm
water inlet on tubby 14mm
oil inlet on tubby 7/16 24 tpi
water outlet on tubby 14mm
hope this helps
ShayneG
Be WARNED - The Halfords ones are not an exact fit as I have already tried them. You will end up doing the job again. FastGuy put me onto a good supplier for these washers and most other Nissan bits you would need when changing the turbo. He sent my copper washers next day and they are the exact OE Nissan ones 8)
http://www.mjpauto.com/ - Go Here and you can get the phone number off the site 8)
Shayne
well the ones i had are still doing fine, been there for a year at least now, they came in a kit of assorted nylon, copper and fibre washers,
you are correct about mike at mjp, very nice chap 8)
