cooling
zia
well here's question for you lot. how do you achieve effective cooling without resorting do intercooling ,direct water inj, using nos etc? :wink: :D
zia
Is this for long running or 1/4 dragging?
Run high compression and low boost :wink:
Chargecooler (but then that's just intercooling)
Fiddle with the aircon so it blows icy air onto the intake somewhere (but that's also a form of intercooling)
Only use the car on cold days in winter :p
Use a bigger oil cooler and lower opening thermostat to reduce engine running temps.
Run lower compression or lower boost to reduce the heat put in by the compression.
Use a fuel cooler to inject cold fuel
if you mean using the fuel to control in cylinder temps then yes.
cant remember what the percentage is but a certain amount of injected fuel is used to reduce in cylinder temps all the time, i guess what you're about to waffle :wink: on about is an advanced form of this :?:
zia
guess what you're about to waffle on about is an advanced form of this
waffle.......waffle..............................................................................
there's me trying to edumagate :wink: you lot . :D
and for your infomation, nope that's not what am hinting at.!!!!
zia
zia
tut................ tut............... dear chap! :lol:
old chinese saying.
what would be the point of offering plate full of quail's when there's no empty stomach's.!!!!!!!!! :D
zia
Allan GTI-R
zia
easy - use methanol.
