didn`t know there were any :? usual method is to remove radiator cap,set heater to full heat,then start engine and allow to idle a bit faster than normal until no more bubbles.
Yep, there is one (copied from the age-old and largely inaccurate FAQ).
>>Find where the bottom hose joins the block, just above the gearbox. There are five bolts holding the outlet to the block, four in a square pattern, and one 'odd' one on the top left as you look from the front of the car. This is the air bleed bolt<<
ok im not sure exactly where they are on the sr20det but heres a general rule:
all bleed lines lead to the highest point in the cooling system, which in most cars is either the top of the radiator (pressure cap) or the header tank
you will find bleed lines running from things like the swirl pot, the heat exchanger and the highest point of the water jacket in the cylinder head to the pressure cap or the header tank.
they are generally small lines of about DASH 10 size
