PaddyPower
People. i had my boost turned up last on tusday and all was hunky doory. Then when i got home the car went bannanna's. After running about in it, normally on 1 bar(but not sure if it has happened on standard boost) the car cuts out at 2000rpm. :shock:
At first i thought it was something to do with the lose sensor on my air filter, but now i think otherwise.
Then i thought is the car getting to hot when running on uprated boost, but then i thought all my gauages are reading the same as they did before the problem, and also lots of peropl run 1 bar on a standard ic?
Any sugestions? As long as i keep below 2000rpm it runs fine? Have done 30mph in 5th all the way home! Every now and then it jumps above 2k and boosts up fine. Me confused as always.
SOMEONE PLEASE COME TO MY AID. I AM AM NOT BOTHERED ABOUT BEGGING
