Confused, how do I fit these to my car ? ? ? ? ?
Y
YODI
Whats the normal routine of fitting different/aftermarket seats to an 'R'?
Cheers, Yodi
You'll probably need some custom subframes making up, if the standard subframes are no use for them.
Y
YODI
Has anyone got these or any other seats in there car??
Yodi
Mr GTiR
i'm in the middle of making some subframes for my Crobeau seats. let me know if you want some subframes making up :wink:
Y
YODI
Can the original subframes be removed from the original seats??
Sirnixalot
nope
they are well integrated into that seat
they have to be hacked off and some welding done....then you have 2 buggered standard seats.
Bride makes some seat rails for the pulsar if you dont get any from Andy 8)
Mulisha
nice skyline and enkei rims. Are you in Okinawa, mainland, elsewhere?
Y
YODI
Im in the UK mate, that pic was taken by the guy that I bought them from
Cheers, Yodi
Mulisha
Oh. If that was your car and you were in Okinawa, Japan, I know you.
Y
YODI
Thecar was only imported in August, is there anything about the car you can tell me??
What do you know aboutit to confirm if its the same car???
Yodi
Mulisha
We are talking about the Skyline, right? If you didn't import it personally than its not the same car. Most of the cars that get imported are from mainland Japan, not Okinawa. That similar car that I know was from Okinawa. But it had boost controller, boost gauge, lowered and front camber like a B!tch. And of course one of the only RB20 manual transmissions on the island.
Y
YODI
No mate
Im talking about my Sunny. Which Skyline are you talking about??
Yodi
Yodi
i have similar seats.
you need to get a new frame thingo kinda thing mayte.
Y
YODI
So I can just rip the frames off the original seats and thats all I will need???
Or were can I just order the correct frames from??
Yodi
Olly
I done it first :lol: You are gonna need a bit of a A Team plan to fit them 8) ,
I used my original runners that were part of the seat :lol: cos stock seats are poor back of them keep moving under high loads :wink: then made and Welded some brackets to the runners and bolted the runners to the orginal Recaro seat position holes, take a while to get them level and right, very comfy but the recaro seats as always have thick seat bases (the bit your arse sits on) so have trimmed mine by 40% to get down nice and low but will go lowerm lower the better lower centre of gravitiy and all that. There worth it but there a bit work to do it. I doubt if Recaro do any runners anything like the GTi-R hillside shaped floor pan very much. :roll:
Good luck
Olly
just angle iron and 4mm thick steel, you should use the stock runners to retain the seat belt mounting (part of runners), then just knock up the brackets and mig it where you want it. if you want a piccy just ask. 8)
Y
YODI
If you couls get me some pics mate that would be excellent
Thanks, Yodi
