I had posted before about the car not pulling that hard after a certain rpm, but now seems worse.
anything after 4500 5000 seems a wast of time and the car seems just to be struggling to rev (like theres somthing holding it back)in 3rd to get from 4500rpm to say 6500-7000rpm it takes from 3 to 8 seconds seems a long time.
But if i turn the boost back to how i had it around 17 - 20 psi it sits you back in your seat till 7500rpm, turn the boost down to 13.5 and a freakin mini could go faster..
specs of the car i presume are all standard apart from high flow cat and the goose...
and before you say you shouldnt be using 17 psi without some sort of fueling upgrade i presume it has a bigger fuel pump cause it hasnt blown up yet and is still running rich, after a year of that...
WILL TAKE IT AND GET IT SUSSED OUT ON THE DYNO, JUST THOUGHT ID TRY AND CONFUSE A FEW OF YOU GUYS......BECAUSE I CERTAINLY AM.
