Compression Ratio
nobwax
Hi guys and girls,
Below is my list of current purchased parts for my build which will be started pretty soon. My concern is the compression ratio I'm going to achieve with the selected Pistons/head gasket combo. I was told it should be fine and I should be able to throw some good boost in there however probably creating more lag than usual which I'm ok with. Can any of you pulsar gods shed any more light on this and if I'm going in the right direction.
Many Thanks
Brian Crower stage 2 cams
Brian Crower dual valve springs
Brian Crower titanium retainers
Brian Crower Adjustable Cam Sprockets
CP 86mm forged Pistons 9.0:1 CR
Cosworth 87mm 1.8mm HG
ARP Rod Bolts
OEM Nissan Head bolts
ACL Race Bearing
Block/head skimmed
720cc injectors
Z32 MAF (blow through or not?)
Stracher Motorsport ext Wastegate Mani
Stracher Motorsport High Flow fuel rail
Garrett GT3071r .82 A/R External Wastegate
Tial blow of valve (not sure on Spring rate)
HKS ebc
NisTune ECU
