comment on moved topic and some thank to diesel weasel
cmng
moderator
i have some comment on moved topic from non member general topic
i posted a topic and 4 pot rear brake system on this section
http://bb.gtiroc.com/viewtopic.php?t=39203
but you moved to tuning and upgrade topic
and i cannot reply to thank the people who upload the link
deisel weasel
that for the link
That link really help me a lot
i have searched all the time for hand brake caliper separately for a long time
Thank man
no problem 8)
i was going to do the the same myself but decided just to use the standard caliper and a 300mm disc.
godspeed kit, 300 and something pounds, and yes it does, brackets are included, managed to trick simon (00sid) into fitting them :lol:, he reckoned they were easier than his so they must've adapted the bracket :wink:
cmng
back to the rear big brake ..
err
it is overkill to fit 4 pot at rear ?
4 pot at rear..
front going to fitted with 325 x 30 4 pot
thinking to fit 300 x 24 disc with 4 pot rear
over kill ?
caliper is brembo monoblock from 996
:lol:
you can never have to much of a good thing in my book 8)
i just couldn't be @rsed in the end :oops: :lol:
Mr GTiR
imo, if you go too big on the rear you stand the chance of overbreaking yourself and may need to invest in an 'adjustable' in car break biasis (sp).
You don't need 4 pots on the rear, just get a big break disc conversion on the rear.
it shouldn't be a problem as the bias is still towards the front so that wouldn't change as you've increased the braking strength on the front anyways.
under really heavy braking the black car has felt like it was going to swap ends a few times which i can only put down to the rears no longer being adequate :?
i did consider doing adjustable bias with the whole 4 pot set up but like i say couldn't be @rsed with the idea and just went bigger rear disc with rebuilt calipers, far less hassle imho
cmng
hehe
thank
problem here is fabrication work is cheap for me since i based at malaysia
and part is reasonable priced
so i thinking to get is 4 pot rear
the car not going to race car
it more like show off and street driving only
i hardly drive above 130 kmh :oops:
the front will consist 996 4 pot caliper with R33 GTR Disc 325 x 30
rear will be 296 x 24 from Mitsu Evo 4 Rotor
i have thinking on brake bias as well
but i think sort out the parking brake first
then decide whether there is need to run brake bias or not later
ps.. i got my used 996 monoblock 4 pot caliper F and R for USD 550 only
with still about 80% 996 OEM brake pad, new retainer and clip
:mrgreen:
