coilpack instead of dizzy
Murff93GTiR
hi guys im going to be running a zytek ecu with aerospec loom and it uses a coilpack instead of a dizzy and i was wondering if anyone has done this before and where to get a seal to block off where the dizzy was located and also how would you set the basetime with it?
jap-jet
What kind of crank trigger are you going to run?
Im running individual coils and still have the dizzy in place running a cam and crank trigger with my multicoil system. Are you planning to run a cdi?
williams
I'm going to use 200sx coils with a megasquirt ecu, will fit a trigger wheel to crank pulley and I'll just use and old 200sx cam sensor to block off where dizzy is.
So because I have a link G4 + in my car my timing regime will be different than everyone else's need to re-sync you see you timing and then put the car into timing
I can go on the ecu and put it in timing Mode put in timing # then I can set it with a gun no taking tps off
