Don't worry I don't know much about them myself . I gather they provide a better ground (earth) for the electrical system and increase voltage slightly as a result and can also give you a smoother idle, and increase low/mid range power/torque slightly.1000ny said:sorry to sound completly dense, but what would the benifits of this kit be?
Micra_Ed said:So pointless.
Yet another ecotek type bodge for a car.
Do people not know that ECU's are supposed to have ONE SINGLE point of ground not a spiders web of them.. Having loads of differnet grounds can cause ground loops that cause more harm than good (hums in car stereos are a fine example)...
You obvioulsy have missed the point.Micra_Ed said:So pointless.
Yet another ecotek yype bodge for a car.
Do you honestly believe that you need massive what looks like 8awg cable to do this?he purpose of these kits are to piggy back all the grounds or run individual wires for wach sensor/grounding point to a single grounding point.
If this is the case these should be delt with properly not bodged by thick pretty cables that somone charges a fortune for.The factory grounds gain resisitance over time.
For this to be possible the resistance of the cable from the TPS would have to be very very high. The input impedence to the A/D converter would be such that even if you stuck a 1K ohm resistor on the TPS you would not notice much if any difference in sampled TPS throttle value.Your Tps sensor puts out 5v @ wide open throttle but with the resistance in the ground the ECU is only seeing a 4.5v signal from the TPS...the ecu provides the maps accordingly, when you think you are at full throttle you iwll actually be running 90-95% throttle instead of 100%.
As I said for there to be any gains, the resistance of the current cables would be such that they would have to be virtually broken. These kits are a complete over kill and are totally un-necessary. Its simply a pretty looking product you can charge alot for because its impossible to prove any gains, unless what is there already is in a REALLY bad state. The best way is to check all the oem grounds are fine, not by bolting un necessary wires all over the engine bay that will do nothing to help at all.It the same principle with your other sensors, they are able to provide the ecu with more precise voltages/readings.
you should still feel bad..you couldve done it for half that but you wouldnt get the pretty HKS logoAllan GTI-R said:thankyou to those who said they work - i feel better now after paying $250 aussie dollars for the HKS kit
now all i need to is install it
