Checking Running Post Boost Increase with blatz
olliecast
Hi everyone! i`m thinking of upping the boost to 1 bar.
I was my car has a walbro pump in but the real question is; can this software be used to determine whether its running ok (i.e. not running lean). It has a lean/rich indicator on but it can only display lean/rich (narrow band lambda sensor i believe)
i`d do a data log run then make sure the afr is rich (better than lean), but could anybody advise what oxygen reading i should be seeing (or a/f base?)
thats the screen with the mearable perameters shown
http://www.blazt.biz/products/images/datascandatadisplay.JPG
then the one below is analysing them after a log run
http://www.blazt.biz/products/images/dviewergraphscreen.JPG
cheers, ollie
Although thats a useful tool it wont be any use for looking at air/fuel ratios, you'll need a separate wideband air/fuel ratio gauge for that ;-)
olliecast said:
so if i took i took it to a garage would they plug in a wideband sensor?
Yes if you took it to a tuner they would stick a wide band probe up the tail pipe probably and run it up on the rollers, That way they can check the fuelling across the entire rev range.
olliecast
spot on, thanks very much mate
