charge cooler
kingy
i can get hold of one and i just wondered if they would be any good on a R
also would it be fitted aswell as a intercooler or inplace of one.
moved- Hannie
You would normally fit it as an alternative to an intercooler. I take it that it's a water to air cooler ? If so, I would advise you to steer clear. It would me more complicated than it's worth. You need to think about a coolant tank, pump, lines, where to put all this. Then theres the weight of all the bit's you would need etc... It would be cheaper and less time consuming to go for a Forge front mount or similar.
Just my 2 p's worth :wink:
Paul
You can also fit them inline with an intercooler too :wink:
They aren't that complicated, just a little more involved than fitting a front mount.
Having fitted the forge front mount to my car and a charge cooler to my last car, the chargecooler went on alot easier :) but I bet on the Gtir, it's an engine out job to fit it. :p :p
L
leeboy
Charge coolers work a lot better than intercoolers, they say their heavier with all the water, i agree but not much, your probably talking 10kg MAX, I bet the ice in some cars is heavier than this.
If its fast road use stick to the intercooler, if its track chargecooler
