Changeing Gears
GTiR_Mic
Finding it a problems when im changing into 5th gear.
1st, 2nd, 3rd and 4th are ok but when going into 5th I have to slowly place it in gear as if i just do it normaly at speed it crunches all the time even with the clutch right down to the floor.
Any ides????
Michael
Rishi
Still waiting on some shims!
Worn Baulk Ring...
Its a gearbox rebuild mate... Sooner or later it will cause 5th gear failure and an even more of a broken box...
Happened to me.... Just got the Quaife after that...
Rishi
Mine does it too. (Doesn't hinder me up the strip tho cos you can't hear it at those revs :lol: )
A couple of people have reported the putting redline mt90 oil in the gearbox has cured their crunching.
GTiR_Mic
Cool, will give that a go. It runs perfect just driving normaly but when i was giving it a bit of boost it seemed to crunch a bit. Car is going off the road in the winter so will decied what i will do with the box then :wink:
michael
GTiR_Mic
Sent him a PM, also to add to this. Been to ld to use a thinner oil rather than the MT90, this a wiser move or stick with the MT90?
Michael
Had the same problem with mine, but with first, second, third.
Took engine out and sent gearbox away, bloke phoned me last week to say the input and main shaft bearings had gone might explain the whine then!
Should get it back on Wednesday back on road the weekend :D
A place in Chester:
Daren Scholes
Tel: (+44) 01829 771165
Q R Sport
Tattenhall
Chester
CH3 5RN
Independent Audi Servicing & Tuning Specialists
View our website at www.QRSport.com
Got what you might call a fecking quick Audi sitting out side there place, 450bhp thing!!
The blokes whos doing it specialises in drag engines and boxes :D
Gaz
GTiR_Mic
Found out Info from my old tunner, he is a nissan hiteq (how ever you spell it)
It is a common problem in all nissan box's in the high powered engines. Due to 5th gear being the overdrive gear it doesn't spin as fast as 1st to 4th. It is basicaly a full bigger gear and need to wase it in when on boost as it isn't spinning as faqst as the rest o the gears. he has the same problem with his Skyline. A decent oil should help, he rates a 50w oil best in the boxes
I wouldn't doubt his info as he has worked for Nissan for years and now a partner in a good tunning garage.
Michael
Rishi
Michael
Spinning of the shaft would be the job of the baulk ring... Which i would suspect is worn as i wrote above... :wink:
Although a change of oil may help a little but i still think you'll need to replace the baulk ring...
Rishi
