central locking solenoid
sooni
Hi all
i think is the solenoid but not sure.when lock the car/drivers door/it locks just d drivers door-not both.when use d switch inside d passenger door locks
do no if they can be repaired-but i suppose put new 1 is better,so if anyone got 1 will be appreciated
cheers thanks
geoff pine
Mine does exactly the same thing I did have a fiddle around with it and it started working again for ashort while I all ways lock the passenger door with the key .
danr
aftermarket are about a fiver off ebay. getting the oem one is a pita as its all attached to the door lock etc.
GTIR-NZ
Could be just the wire attaching the connector inside the door where it connects at the bottom of the window frame. I have both door looms if they are of any use?
