Lol, someones probably had a bit of a poke around in there to make it effectively a straight thro pipe. Your still better off without it.GTIR1000 said:tokk mt cat of at weekend to find it was hollow what is going on thought they were meant to have stuff in them
Lol, someones probably had a bit of a poke around in there and got rid of all the insides to it, to make it effectively a straight thro pipe. Your still better off without it.GTIR1000 said:tokk mt cat of at weekend to find it was hollow what is going on thought they were meant to have stuff in them
would just be the same as you are effectively running with a decat pipe nowGTIR1000 said:would putting a decat pipe on be better or would it just be the same
This is a bit nit picky really but, if the cat is completely hollowed out, this will give a space for the exhaust gas to expand and cool. This will slow down gas flow out of the engine and therefore reduce power etc... Put a piece of straight through pipe, the same diameter as the rest of the exhaust, in it's place for the best solution. You may even notice more urge, you may not !oap-r said:would just be the same as you are effectively running with a decat pipe nowGTIR1000 said:would putting a decat pipe on be better or would it just be the same
