:lol: :lol:No, you'll struggle to just get a standard carbon bonnet nevermind one with a evo vent - although fu.ck knows why you'd want to put something sh.it like that on an R in the first place.
Paz
Because if you've got rid of the top mount, then an evo vent (no gtir scoop) would help improve the aerodynamics of the car and people wouldn't get beaten by BMW 330s as easilypaz said:No, you'll struggle to just get a standard carbon bonnet nevermind one with a evo vent - although fu.ck knows why you'd want to put something sh.it like that on an R in the first place.
Paz
So if I shave a couple of inches off the top off a brick, does the same theory stand? :lol:Fast Guy said:Because if you've got rid of the top mount, then an evo vent (no gtir scoop) would help improve the aerodynamics of the car and people wouldn't get beaten by BMW 330s as easilypaz said:No, you'll struggle to just get a standard carbon bonnet nevermind one with a evo vent - although fu.ck knows why you'd want to put something sh.it like that on an R in the first place.
Paz
My thoughts exactly.Fast Guy said:Because if you've got rid of the top mount, then an evo vent (no gtir scoop) would help improve the aerodynamics of the car and people wouldn't get beaten by BMW 330s as easily
paz said:So if I shave a couple of inches off the top off a brick, does the same theory stand? :lol:
Besides which, if the top 'cooler has gone, why is any vent needed
Paz
Fast Guy said:paz said:So if I shave a couple of inches off the top off a brick, does the same theory stand? :lol:
Paz
1) Err yes, of course it will It's all to do wit CdA (coeffiecient of drag times frontal area) lowering your suspension should achieve the same effect to a degree
2) Have you ever seen your bonnet trying to lift at high speed? All the air that goes though the radiator/front mount is trying to get out somewhere, mainly it has to force it's way out under the car but if it could hit the turbo and vent out straight upwards it would save it struggling to find another way out.
Couldn't you get a gti one for now and get a bodyshop to modify it, then when you're happy with it you could send it off to have a carbon one made.RishiGTiR said:Exactly... I need a carbon sunny GTi bonnet or a custom one with a vent for venting out hot air from under the bonnet...
Rishi
already solved that one matey , disco-ago-go had a moment of genius and will be doing it to my fibreglass bonnet 8)Fast Guy said:vent out straight upwards it would save it struggling to find another way out.
Fast Guy said:Couldn't you get a gti one for now and get a bodyshop to modify it, then when you're happy with it you could send it off to have a carbon one made.RishiGTiR said:Exactly... I need a carbon sunny GTi bonnet or a custom one with a vent for venting out hot air from under the bonnet...
Rishi
There is the Turini one, but I thought the exit holes from the vents were too small to be of alot of use.
