Fitted new air regulator took off the plenum, inlet, tps and fuel rail
Fitted it all back together then cranked the car over due to the fuel rail being empty it took about 5-10 seconds then fired up, left it to warm up for 2 mins, then it sat on idol at 950rpm
Had a few more parts to put on the car e.g strutbrace and bonnet so i turned the car off when i was ready to go out on my test run the car wouldnt start so i checked everything and all seemed ok.
I rang my mate up for some help when he came round he took the furthest spark plug out to check for a spark by leaving all the other spark plugs in except the end one placing it on some metal still in the ignition lead, we cranked it over there was a spark so we put it back in turned the car over and it started then turned the car off tried to start it again and it wouldnt start, tried the same method again with the spark plug and still wouldnt start also i know there is fuel going into the rail as whe i disconnect the fuel pipe on the rail, fuel comes out
the car started 2night i took it out for a drive to get it warm, came home after 15min turned it of in garage tryed to start it again nouthing
What i can say is it now sits on idle perfect 950rpm
2 things i can tell you is the idle control srew has been messed with bye me and i guess the last owner who had this problem cos he told me upon sale, its srewed all the way in so i dnt no how you determan what is should be at cos it fires up sits at 1250rpm till warm then sits at 950rpm
Second thing i noticed, this didnt happen before, was that the temp gauge on the dash goes mad up and down but when you stop the car it sits fine i no i lost a little water when changing air regulater but it was very little i also fitted new temp switch
Any ideas wat cousing this not to start second time when remove plugs there a little wet
