Car pulling left after alignment
Perrin21
I have had my car aligned but it hasn't solved a pulling to the left issue I have. I understand the camber of the road plays it's part but it's still pulling. It's ok if I hold it straight but then it drifts left. Any ideas where I should start? Was thinking brakes first.
danr
think they all pull left a little, even with 4 wheel alignment. think theres some quote on here from powerstation saying off all the 100s theyve done they pull left a little. only way to rectify causes wheel scrub.
mine pulls left, but im a bit beer belly impaired. if someone sits in the passenger seat it evens it out. also macpherson struts are prone to this iirc, shorter driveshaft on left will cause torque steer to that side. knakcered front diffs can do same.
but i think its just a 'thing', but im sure sure some more knowledgeable person will be along ...
Mine tracks pretty true; plus it's a near standard setup. - I did have to get the ARB mounts re-welded for the last MOT, so maybe they're straighter than most now?
