car feels slow / sluggish its defo not as quick
HI
As stated its slowing up what could be the problem???
its had a little service oil oil filter air flow meter cleaned spark plugs looked over not changed.
ive done a fault code chech just number 11 every now and then not pernament its been like it ever since owning the car
I did think it was me at first but me dad has been out in it and says the same thing its lost some go.
any info or advise would be very helpful and much appreciated
thanks
sam
bensmith907
have you checked the timing recently? also as im sure your aware fault code 11 is the crank angle sensor not reading 0/180 deg properly. I would check the plugs for that, also consider a new dizzy if they're fine
pulsar350R
how did you clean the air flow sensor??? as you stated it was cleaned
which spark plugs are you using?? try gapping your plugs to 0.7mm,
was cleaned using a spray witch i have used on my pulsar i had civic vti and now the sunny so i know thats not at fault no i havent touched the wires ..
standard ones that i have been advised from maney people ngk bcr8ES I think cant remember off my head
thanks
sam
