Nothing new there, what gti-r does like tight corners :lol:weakboy2 said:car doesnt seem to like going round tight corners
weakboy2 said:could be, seems like its locking, have the R's got Lsd's as standard? seems as tho mine has been tinkered with, looks like its got solid engine mounts as i cant move the engine AT ALL and the rubbers are really hard, which would explain the vibrations i get through the steering wheel on idle!
i find its good for the back;-)weakboy2 said:heh! means i got solid ones then!! at least thats why the car vibrates so much then!
Did the gearbox show you any other signs of damage , what i meen is on straight line driving slight turning etc was the box notchy or hard to select, as my gearbox seems one of the best boxs ive had in a car, thats whats so puzzling:?vss irvine said:its the gearbox that i had a problem with, not the centre diff(transfer box).
the symptoms were the same. the car was really hard to manouvere in tight angles. having to give it a load of throttle to make it turn.
spent weeks changing everything, then changed the gearbox and it was sorted.
the only thing i can think of, was before we bought the car, it had been towed 30 miles at 50mph, so i reckon that damaged the box
A knackered diff won't affect gearchange quality though ! ;-)Jul said:Did the gearbox show you any other signs of damage , what i meen is on straight line driving slight turning etc was the box notchy or hard to select, as my gearbox seems one of the best boxs ive had in a car, thats whats so puzzling:?
i didnt say it would:roll: . i will refrase the question as maybe im not explaining my self to clearly:youngsyp said:A knackered diff won't affect gearchange quality though ! ;-)
Towing a GTiR, with all 4 wheels on the ground will most certainly knacker one, if not all the diffs. So, I suspect, if you're having similar issues, this could be your problem !
And I didn't say you did either ! :der: ;-)Jul said:i didnt say it would:roll: .
