What ECU are you running? - I think uprated options like Nistune and the after-market ECUs can use the wideband signal instead, but the standard ECU gets a bit funny about it.
I could be wrong, but I think it's because the car uses a titania probe rather than zirconia. - So it doesn't output a voltage with change in mixture; instead the resistance across the probe changes when voltage (5V?) is applied to it (that's why there's three wires, not two)
As a result a wideband sensor emulating narrowband may not give a signal the ECU recognises.
