Camber bolts front and rear
Can you just get the pillow-ball topmounts (or whatever they're called) and fit your existing shocks into them?
olliecast
We`re going to do the castor mod next weekend as he`s already got tein topmounts.
The camber bolts were to be used instead of doing the course camber mod (i did both on mine in the end as the camber bolts didn`t give me enough -`ve)
vss irvine
'' (i did both on mine in the end as the camber bolts didn`t give me enough -`ve) ''
why bother with camber bolts then, do it right, do it once?
saves you setting the suspension up twice.........
olliecast
was playing with different settings.
You sent me a set of normal bolts, so i`ve used them now but keeping the camber bolts if i did ever want to change
Tim
I'm fine with doing the coarse camber mod if you are happy with that Ollie?
If not i'll grab the bits necessary, your call :thumb:
olliecast
do you want your coilover holes elongating?
Their your suspension :)
i prefer the coarse mod, less things to slip
