cam tensioner
jjs
hi just fitted a new set of cams, with the engine in place , have to reset the cam chain tensioner, is there an easy way to do this without removing the tensioner from the head ? jim. ;-)
stumo
You'll need to remove the tensioner.
It has a ratchet to stop it moving back.
As long as you don't move the crank or cams when the tensioner is out you'll be fine.
