gtirx2
Ok i have just behine checking my valve clearences and they are all a little on the tight side about 0.015 to 0.020 max cold and about 0.020 to 0.030mm max hot are these clearences to tight or should they be ok?Also on a couple of the cam lobes there were some very light scuff marks on some of them and i can't work out what could of caused this, could it be because the clearences are a bit tighter than they should be or do you think this is something else?The rockers all move freely enuff when you move the cams in position to measure the clearences so surely it could not be because of the clearences are a little too tight:? I don't nessaseraly think its a problem as i have run the car like this for a good few thousand miles with no problems but i am just wondering what could of caused the light scuffing on the cam lobes i supose it could of just behine crap that has gone under them but i just wondered what you guys thought?
Heres a poor pic of the marks if you look close you can just make it out.
http://i102.photobucket.com/albums/m114/gtirx2/pict0004.jpg
