Caged, Built, R
CruiseGTi-R
Hello All,
After 10 years of building my car the time has come to find her a new home.
Bought in 2005 as the first UK owner I’ve spent many years (and scary amounts of money!) to get it to where it is now. It’s a 1994 M-reg.
The spec hopefully speaks for itself, which has gone through quite a few iterations.
As I work abroad, I’ve only been able to drive the car a couple of times a year, so the mileage on the engine and most of the modified parts has been pretty low. The cage, seats and coilovers were the last few things on the car which have barely seen 1000 miles. The engine around 5000 miles, which is a real peach and has been faultless. The Quaife was re-built around 2000 miles ago with a new clutch too.
Whilst the engine was built with the usual 400bhp in mind, I never got to actually fit a different turbo – it’s still running the same stock turbo I had when I bought it…!
The cage totally transformed the way the car handles, can’t say enough about how different it drives. The cage is the full T45 multipoint weld-in from Custom Cages, with triangulation through to the front strut towers and I also had them add a-pillar double bars. It’s MSA/FIA certified (including the additional a-pillar bars).
The BRIDE seats are on the BRIDE GTi-R subframe rails, which adjust fore and aft.
Over the years the usual rust spots have been sorted, rear arches, passenger footwells, lower sills, and was also re-sprayed in full. It’s always been MoT’d and insured.
I’m looking for £6,950. Lots of other things to mention, but here’s the spec. If you’re interested or have any questions please drop me a pm.
Chassis:
Full FIA/MSA Multipoint T45 weld-in, from Custom Cages, including additional a-pillar supports and modified door bars, front-turret triangulation and dash bar. The cage is also stitched to the a-pillars and b-pillars.
Fully polybushed (mix of Whiteline/Powerflex etc), Nismo steering rack bushes and shifter Bush
Coilovers are BC (BR Series Type RA).
Whiteline front and rear arb’s
Bumpsteer Kit
17” Compomotive MO’s (with R888’s)
Rallynuts Wilwood 280mm kit (recent new s-s lines)
Braided Front and Rear (custom) Lines
The seats are BRIDE ZetaII’s along with the BRIDE low-max rails, on BRIDE sliders (all new direct from Japan).
Harnesses are TAKATA 6-points (crotch strap has eye-bolts welded to the floor).
Deep-dish OMP Steering Wheel (Oval GT cross section)
Engine Build:
Reconditioned Head (with new OE parts)
JE pistons 87mm (will all optional oil drilling and coating)
Pauter H-Beam rods (also with optional oil drilling)
Crank Lightened, Knife-edged, Polished, Balanced
ACL Bearings
Full ARP set
Cometic 87/1.2 HG (both block and head flattened)
Fidanza Lightweight Flywheel
ACL Main (19mm), Rod, Thrust Bearings
New GTIR OEM Oil and Water Pump
New OEM Timing Chain, Tensioner and Guides
New OEM Seals/Gaskets
Stock Turbo (same turbo since owned the car)
Daughterboard fitted and Mapped by Ed
Gearbox:
Gearbox has Quaiffe gearset + New Syncros, Baulk Rings and selector forks
PPG 3/4th Billet Selector Fork
All new Nissan OE seals + bearings
Exedy Organic Clutch
Braided Clutch cable
New Clutch Release Bearing
Nismo Clutch Pivot Ball
Reinforced Clutch Fork
Clutch Support Bracket
Ancillaries/Other:
Reconditioned Power Steering Pump
Reconditioned Steering Rack
Mocal Oil Cooler with Mocal Thermostat take-off plate (only just installed)
Pipewerx Custom 3” Exhaust (with custom backbox), from turbo elbow back.
Absolute Radiator 25mm
FMIC (powercoated black pipework)
HKS SSQV BOV
Samco full GTIR Hose set, including rears
Apexi Air Filter
Body:
The bodywork has had continuous work done over the years.
A full re-spray in KH3, full interior and cage is Nissan White.
The rear arches have been repaired (they weren’t too bad, but did it as part of the re-spray work).
The underside has had small patch repairs to the rear passenger footwell.
Weld up R/floor N/S & O/S
Weld up chassis leg at anti-roll bar mount
Wax'd/Undersealed
