Bumpsteer Fitting ?
j10gtr
Hi,
Anyone got any bumpsteer fitting hints / tops including the rubber covers . Any pictures would be great.
Paul
If you have the same rubbers as I got, I found it pretty easy to slide the bearing threaded portion in through the top or bottom holes and out of the side where it should be. Other than that, it's as easy as replacing a track rod end normally.
Not exactly, just a machined balljoint bit and the rosejoint which go together to replace the standard track rod end.
